Limited Editions: We Fade to Grey
18th March 2026
Celebrate All the Shades of Grey
Keeping it sleek with the neutral shades.
Sometimes simple is best. This week we are fading to all of the shades of grey. But hurry, when the Limited Editions are gone - they’re gone! The beauty of the Limited Editions is that they are in stock ready for immediate dispatch. We create a limited run of these pickups, which are all handwound and made at our Cornish (UK) workshops. This way, you can find something you like, hit "buy" and before you know it, it's arrived at your door!
This is one of our latest releases, the Halcyon in grey carbon. These are our custom Mike Stringer signature Halcyon 6 string humbuckers in open coil spec with grey carbon tattoo bobbins.
Sign up to our newsletter here to get weekly updates from our Limited Edition range.
Here's our Adam "Nolly" Getgood Polymath humbucker set with custom white / black Polymath etch bobbins and TV covers with black bolts.
A very special edition Misha Mansoor Ragnarok 7 string humbucker set, with black bobbins, black bolts, custom skull etch and 4-conductor wiring.
The irony is that you will stand out from the crowd with this Misha Mansoor Ragnarok 6 string humbucker set, with 53mm bridge pole spacing, 4-conductor wiring and custom black / nickel camo covers.
Another of Adam "Nolly" Getgood's signatures, a 7 string Polymath humbucker set with custom white / black Polymath etch bobbins and black bolts.
A really classy custom Riff Raff humbucker set in nickel / clearcoat finish, with paisley pattern etching and nickel pole screws.
